Kenmore Elite HE3 Dryer runs but won't heat up
Worked fine yesterday, wife put a load of clothes in today and dryer never heated up to dry clothes. I read a lot of other posts,. but none of them had same model number.
Need help, hate to call service man if I can DIY. Where do I start? Thanks Ives
Here is your tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203980060.pdf
I would start by checking the power
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
HI Denman,
i am in experienced in using this site.
Can you take a look at the post I put in the Dryer section at 11:50 this AM.
I need to head to town soon for paarts it is quite a drive and I need to get stated if I plan on getting this fixed today.
Dennis Stroklund
