Kenmore Elite Oasis leaking
Hello,
I recently replaced the drain pump on my kenmore elite oasis top loader washer.
Today I found a little puddle in the front of the washer. I checked the back and only found water in the front of the washer. I felt under the washer on the insulation on the drum and only felt water on the bottom front of the insulation. I could not feel it anywhere else.
Does anyone have any idea what could be leaking on the washer?
Check all your drain and recirc pump hoses and your inlet valve hoses underneath the control you’ll have to remove the back of the unit…If it’s not coming from any of those spots you probably have a cracked tub or tub seal/bearing going bad it’s really common on those units. Does it make excessive noise while agitating or on high speed spin?
Thanks for the reply. I will double check the connections. Not sure if it makes excessive noise. I will pay attention next time the machine is on.
Tks again.
