Top Load Washer
My Kenmore Elite Oasis HE Washer Model 110.27072602 is leaking water through the holes in the bottom of the rotor during the agitating cycle and the spin cycle. Water with grease is being thrown on the floor in a circular pattern. Is there a seal on the outer tub above the motor? If so, do you have procedures for replacing it? Thank you.
