Leaky top load washer
Hi, my top load Kenmore Elite 111 is leaking water and it appears to be coming from the upper right corner. I think this is during the spin cycle. is there a gasket or something like that in that area that could be bad? I cant lift the lid to look while its running. Thanks for your input.
Can you locate the full model number? should be about 11 numbers total.
Nat
i can here the timer, the door switch seems to be working, i don’t know what’s wrong… PLEASE HELP ME!!
Check the Thermal fuse at the back. It is the small white plastic piece either on the blower housing or near the cycling thermostat. It normally goes if your venting is obstructed.
— Begin quote from jefferybeecher73@gmail.co;191234
washer hums wont do anything else
does anyone else have this problem.
