kenmore fridge has stopped the light stills comes on when opening the door but the fridge and freezer are not getting cold and the pump is not kicking on ?
If everything besides the interior lights is dead, then most likely the refrigerator stuck in the defrost mode.
Locate the shaft on the defrost timer (#23 on the [AP2111929](http://tinyurl.com/2r65fs"]break down diagram[/URL]) and slowly turn it CW.
If, after it clicked, the compressor kicked on then the defrost timer is bad and has to be replaced.
- The part number for the defrost timer is [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=2111929)
Try to bypass the cold control (aka thermostat).
If it would not help then probably the compressor is bad.
I have a caloric oven that will not turn on. The burners light but the oven does not. I have removed the spark igniter and tried to light it with a lighter. I am not getting any gas out of it.
