Kenmore Model 90 - (110.26902692) washer works fine up to drain/spin. I manually checked the lid switch and relay seems to work/click ok.
Took the pump off after reading some posts. There seem to be no obstructions or socks in pump or hoses, but don’t know how to tell if pump is working as it should. It spins with my finger but doesn’t keep spinning like a roulette wheel. Should it?
I suspect the timer control unit. Any thoughts?
