Kenmore Refrigerator Water Dispenser Won't Work
my Water Dispenser In My Refrigerator Wont Work.
1. The Ice Maker Works Fine
2. The Freezer Door Is Closed
3. The Water Tank Is Filled
4. There Is Not A Kink In The Water Line
5. The Water Filter Is Not Clogged
but When You Press The Dispenser No Water Comes Out?
can You Help?
You have two separate solenoid valves. One feeds the ice maker the other one feeds your water dispenser. You can shut the water off, take the hose off and clean the strainer. or you can check for voltage going into the solenoid, press for water and check power going into the solenoid that is feeding your water dispenser.
Is in the back-Botton of the refrigerator where the main water line is connected to the back of your fridge… Your model number doesnt come up, is missing three numbers.
I will look and get back to you tomorrow. by the way the entire model number is: 106.59582990
Ok I Checked The Strainer, Not Clogged. I Tried Testing The Solenoid As You Asked, By Pulling The Connectors Of What I Believe Was The Solenoid. I Had My Wife Depress The Water Dispenser, I Connected My Voltage Meter To The Neg And Pos And Received A Zero Volt Reading. Funny, I Pulled The Second Connector To What I Believe Was The Icemaker And Also A Zero Reading. To Make Sure, How Do You Exactly Check The Voltage?
Still awaiting your reply to previous question!
it Has Been 3 Days, And No Response? Is This Problem To Difficult For You? Should I Go To Someone Else?
