I have a Kenmore electric stove that is about 12 years old; the model number is 6880630505090, the serial number is IME1662805. When recently baking something, there was a bright flash from the base of the oven which then glowed orange for a few seconds. The oven’s bake element no longer works although the broil does, as do the burners, clock, and oven light. When I try to heat the oven, it doesn’t heat to the full temperature as the light never goes out. Does the bottom element need to be replaced? If so, can I simply purchase one at a store like Home Depot and do it myself?
The model number posted does not come up, can you see a visual break in the bake element?
Nat
Then it does need replaced. There are two screws that hold it in place, unplug the range and remove the element. Look for a part number on it or take a picture and measurements.
Nat
I’ll try that. Thanks very much for your help, Nat.
Keep us posted.
Nat
I bought the element, installed it with no problem and the stove works well. Thanks Nat.
