Kenmore Whasher fills up w/ water then stops
I’ve got a Kenmore washer (top loader) Model #:110.24422300.
I start a load and it fills up with water as it normally does, and then it just stops. No noises, no smells. I’ve turned the knob to several other cycles to see if it would start back on but nothing happens. From what I’ve read in other threads, it looks like it could be the lid switch?!? Is this the only thing I should check/replace before I start dismantling?
I would start by checking the lid switch - do you hear a click when opening or closing the lid? if no then the lid switch needs replaced
Thanjks Qtip,
It was the lid switch that was broken. Washer works good now.:slight_smile:
