Kitchen Aid Architect Series II
My oven no longer ignites when I turn on "bake". It starts to heat up when I set it to "convection" baking, however it eventually stops preheating so it never gets to temperature and then goes off. I did test the "broil" and that seems to work fine. Any idea what is the problem?
Hi.
The easiest way to check if this is the ignitor issue is to switch the bake and the broil ignitors around, in your case there are identical.
If the Bake start working - replace the ignitor
74007498
To be sure on the part number, please provide the complete model number of the unit.
Simon.
