Kitchen Aid Oven Won't Ignite
Hello guys,
The oven part of my gas Kitchen Aid convection range is not working. I’ve been looking around trying figure out exactly what the problem is and have not been able to resolve it yet.
Both the bake and the broil features are not working on the range. The problem initially was intermittent where sometimes the oven would heat up and sometimes it wouldn’t. However, more recently it quit working completely.
When I use the bake function nothing seems to happen besides the screen changing. However, when I use the broil function, the convection fan turns on, but it does not heat up.
I’ve been testing some different things and don’t have a definitive answer on what it is.
I found continuity in the temperature sensor.
I also removed the leads and tested the ignitor/gas unit underneath. I attached a picture of this below. There was continuity between the bottom two leads, but not between top two. Oddly, enough there seemed to be a voltage between the top two when i turned the broiler on.
Anyways any help would be appreciated.
edit: Added pictures
