Oven was taking long to reach baking temp, sometimes only reaching partial temp (did not observe what was going on), now does not heat up at all. Ignitor fires and stays on, but gas does not come on (maybe slight gas odor). Broiler works fine and that ignitor shares the same gas valve as bake ignitor. Do I need to check for voltage at valve and/or that ignitor is hot enough (is that the same thing?) or do I have a no-brainer faulty/weak bake ignitor? Does it make sense to try to swap the bake/broiler ignitors (the appear to be the same) to see if bake then works? Please help diagnose…thanks!
Related topics
No Bake Oven | 1 | 1238 | January 30, 2014 | |
broiler works but will not work on bake | 0 | 968 | July 17, 2011 | |
Kitchen Aid Oven Won't Ignite | 1 | 682 | November 25, 2015 | |
Troubleshooting Broiler Problem | 1 | 1120 | August 9, 2013 | |
oven wont heat but broiler and range work | 3 | 3336 | November 7, 2009 |
