I know this is a common problem and has been discussed on this forum however I cannot find parts specific for my model number.
The stove shut off and remained locked after self clean. Using the instructions offered on this forum I was able to open the door with the latch.
From reading this forum I understand this problem is most likely related to an open fuse. Please provide part numbers to replace the open fuse (or fuses) along with instructions.
Also there was a problem prior to this issue whereby the stove would not shut off using the control panel. I figure this is the control board?
Please provide instructions and part numbers for this as well.
The oven is Stainless Steel.
Thanks.
