I know this is a common problem and has been discussed on this forum however I cannot find parts specific for my model number.
The stove shut off and remained locked after self clean. Using the instructions offered on this forum I was able to open the door with the latch.
From reading this forum I understand this problem is most likely related to an open fuse. Please provide part numbers to replace the open fuse or fuses along with instructions.
Also there was a problem prior to this issue whereby the stove would not shut off using the control panel. I figure this is the control board?
Please provide instructions and part numbers for this as well.
Number 37 in the picture below is the thermal fuse that has likely opened during the cleaning cycle. It is mounted on the rear of the range, behind the access panel numbered 50 in the picture. It may be tested for continuity and if found to be open, replaced with the correct part available from the link below.
As for the oven not shutting off with the control panel, the touch pad is likely faulty. Does it beep when you press the off button or do nothing, as if the button is not working?
Pressing the off button did nothing. No beeps. Also, pressing the zero key did nothing either (so the oven could not be set to a temperature ending with 0).
Okay, so it is likely the touch pad is faulty. You may need to replace the touch pad but there is a trick you can try first. Turn off the power to the appliance. Use a hair dryer to heat the panel up until very warm while rubbing firmly over the buttons. Often times, this will restore operation. Be sure to get the panel very warm but not hot enough to damage the plastic. If this does not work, the panel will likely need to be replaced. Let me know what happens and I can get you the correct part information.
