KitchenAid Oven ERC?
Folks,
Our oven just died with an F1E7 error.
I think that is the electronic range control (ERC)?
The oven is approx 13 years old and think we should probably replace the probe sensor in back of oven as well.
Looking for part numbers, schematics and advise/ direction on changing it out.
thanks for any assistance! Good bless!
HI, Lance.
You are right - the F1E7 means bad ERC.
The ERC AP3135399
Here are the step by step:
  • disconnect the power
  • open oven door
  • remove the bottom screw from each side of the trim
  • pull trim’s bottom out and down
  • remove screws from each side of the oven control panel
  • pull panel out at the bottom and lift
  • disconnect the wire connectors
  • remove 5 screws holding the control board
  • lift the ends of the locking arm and disconnect the ribbon
    cable.
    Handle the new control carefully it’s sensitive to electro static discharge.
The temperature sensor AP3008972
Her are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=259640
Thank you. Post the results.
