hello,
I’ve got an LG electric dryer, only a few years old, and midway through a cycle it just stopped. I went to restart it but it would not power on, despite the fact the light was on inside the dryer. I flipped the breaker on and off, still nothing.
I checked the vent, which is rigid, thinking it might be clogged and had tripped things, but it was quite clear.
I did some searching and found suggestions:
- pressing reset button inside the machine - via the dryer vent hole - but my version is electric and doesn’t have this switch it seems?
- I tried turning off the machine, holding down power button for 5 seconds then turning on again.
- some people suggest that it could be one of the thermal fuses - and I haven’t checked the continuity on these yet since I need to borrow a multimeter - but before heading down this path, which seems to involve dismantling the entire machine…? i wanted to be sure that the symptoms point to this, and not to something like a faulty control panel?
What might my next steps be?
Thanks in advance for the wisdom,
Paul
