I have an LG washing machine, model number WM2277HW. The drum will not turn. It starts to load water but then the drum does not turn and it also will not drain the water that it has now added. There is a humming noise and after approximately 5 minutes the LE code appears. I replaced the drive motor stater assembly part AP4438648 (4417FA1994G) and the rotor assembly part AP4438635 (4413EA1002B). What should be the next step?
Related topics
Washer puts water in drum does not turn only hums and water does not drain | 2 | 2072 | July 4, 2012 | |
LG washer drum won't turn | 2 | 1136 | October 11, 2014 | |
LG Front Load-LE Code- Drum wont turn | 18 | 30681 | May 8, 2015 | |
LG washer will not spin | 1 | 1547 | July 17, 2012 | |
LG Front Load Washer Barely Spins | 3 | 827 | March 3, 2017 |
