Loud Humming noise
All of the sudden a loud humming noise is coming from the machine. Sounds like a motor is stuck or something. Are there belts on this model that could have broken and need to be replaced? I checked the inlet screens for blockage and the drain pipe (figured I would try the easy stuff first) but no luck. The machine is still filling fine but I think its something wrong with the spin cycle. Any help would be greatly appreciated!
If it drains, but doesn’t spin, you’ll need to replace the motor coupler assembly (a relatively easy job).
Your panel screws are in the back on each side, just unscrew both pull forward and tilt panel back.
I would advise to fix this soon, I have seen too many burnt motors from this kind of failure!
Will do, the washer has been out of service since this strange noise has started. Thanks for your advice I appreciate it!
