Low Water Pressure
[SIZE=4]Mfg # PARS9268BCO[/SIZE]
[SIZE=4][/SIZE]
[SIZE=4]Water pressure low while dispensing water from door front. Ice maker working fine. Changed water filter. Suspect either the main water valve or the kit, water valve, but don’t know which to order.[/SIZE]
[SIZE=4][/SIZE]
[SIZE=4]Thank you,[/SIZE]
[SIZE=4]Chuck123:) [/SIZE]
— Begin quote from mral;130826
I have the same problem with my Kenmore side by side. It’s intermittent either no ice making/water dispensing, or ice making and very weak water dispensing. Judging by the age of my unit (10yrs), I’m guessing it’s the inlet solenoid valve as there’s good water pressure to it. good luck
Thank you for the help.
After getting several good comments I ordered the main water valve and that FIXED the problem. Lots of pressure at the frig door. Works like new.:wink:
