Lower Element Was Broken So I Replaced…easy Fix. But New Element Wont Heat …any Help?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MER6549BAQ
Sounds like the control board is shot.
Double check that the element is still connected.
Chek that the wires to/from the element are OK.
Ok thanks but I think your right …after replacing element the first time there was a small puff of smoke from the stove that we couldn’t locate the source …control panel still works for the other oven
