Not sure what is wrong my washer does not do anything when you pull out the timer knob power to machine is good any suggestions
Does your indicator light come on?
Is it possible that the problem is the door switch ? How can i check any help would be greatly appreciated
If you have not light, I would start with the basics, check your breaker box. Turn the breaker off and then back on and try it again.
Nat
Would anyone have a diagram for replacing the water actuator in my double-door Frigidaire refrigerator? Thank you, vjmonroe@kiva.net
Here’s a diagram showing the parts and screws etc. No instructions but you can maybe figure it out http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLHS67EESB9&productCategoryId=0165000&brandId=1428&modelName=REFRIGERATOR&diagramPageId=00007&componentDescription=ICE%20&%20WATER%20DISPENSER&documentId=R0508189&backToLink=Return%20to%20Sub%20Components%20list
How To Replace Water Actuator On Model Glhs38ees Refrigerator?
