At the end of the rinse cycle, the washer does not go into spin and the timer indicator light goes blank . It does not display an error code.
I can not get your model to come up, can you check the model number.
If this is a front load washer the likely suspect is your motor control/speed control board.
GLTF 2940 ES is the model number. I too think that it is the board because it doesn’t give an error code as it does when the coin catcher is full.
Thanks for your help
I have a very old westinghouse wall oven that the thermostat has quit working. I can’t find a part anywhere. Will have to tear out all my cabinets to put in another oven. Any help?
Ice dispensor motor not working. Water will dispense so I swapped the two activator switches in hte front side of the door to see if it was that. Still had the same problem and water still dispensed with the other switch. How do you access the motor? I tried removing the pannel under the ice bucket but am affraid to break if I pry too hard. I removed the front cover on the door but could not get the scondary panel off. Again didn’t want to pry too much in fear of breaking.
Yes I tried both cubed and crushed
I don’t have anything that comes close to your model number. Is your ice dispenser in the door, or is your ice maker attached to the side of your freezer?
Sorry I did a typo on the model number. It is GS6 not GSS.
