Magic Chef F1 code?
[COLOR=red]We have a rental house and it has a Magic Chef wall oven, they cannot find a model or serial number. They say an F1 shows and then it starts to beep. Any ideas what this might be and what I need to do to fix it. No manual available[/COLOR]
— Begin quote from happyfeet;23934
any advice on what it is telling me and how to fix it or stop it permanently
Most likely the problem is a bad touch pad.
Perhaps the following will help find your model number.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Make sure the unit is unplugged before doing any of the below.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
On a Magic Chef F1 does come up as a sensor problem but that can vary depending on the Model.
Could be that you have a bad solder connection or a cracked circuit trail on the control board.
