I inherited this appliance when I purchased the home, so I don’t now how old this range/oven is. I noticed other people having the same problem with the display of the F1 and the constant beeping. All I know is when I remove the panel (membrane) on the outside that has the buttons, my problem goes away, so it sounds like I should replace that part. However, there are those that have the same problem and have replaced that part and still have that problem. Of course, neither part is cheap and I cannot return the item is plugged in, what would you suggest?
Dennis:confused:
