Magic Chef Problem
[SIZE=3][SIZE=2][COLOR=#333333][FONT=Verdana] [/SIZE]
[SIZE=3]I have a Magic Chef washer and when the cycle calls for the machince to agitate or to spin out it just buzzes. I have replaced the timer and the lid switch. It still does the same thing. If I bump the lid open and closed a couple times it will start agitating or spinning. [/SIZE]
[SIZE=3]Does anyone have an IDEA of what is going on?[/SIZE]
[/COLOR][/SIZE][/FONT]
[SIZE=3]Bumping the lid switch to make it run sounds like a lid switch problem but you already been through that. The motor buzzing sounds like the water pump is locked up, this happens a lot with these pumps. Take the belt off and attempt to turn the pump by hand, it should turn freely if not replace it. http://www.appliance-repair-it.com/Maytag-washer-repair.html[/SIZE]
My whillpool electric stove self cleaning oven not working.The oven door locks and the timer shows 3 hrs but the elements will not come on.
John,
What is the complete model number of the oven?
