All of the wash cycles work like they should, if I want hot, warm or cold, it does what it should. The problem starts with the rinse cycle, the rinse should be cold but it gives warm water instead. I was thinking it is the temp control switch but I’m not positive.
With temp set to other than WARM/WARM, disconnect terminal on back of temp switch that has the orange wires. If you still get a warm rinse, the timer is bad. If you now get cold rinse, temp switch is bad.
Eric
