My dishwasher will fill but the wash and drain cycles won’t turn on – just clicking noise. I removed control board and found 2 resistors were hot to touch and the board was discolored where they are located (R301 & R302)
It looks like they could be the problem. Do I need to replace the whole board or can I just replace the resistors. Where can I find a new control board if it needs to be replaced? There is a number on the board 60D20960401. Thank you for your service.
You would have to replace the board.
The resistors are probably OK since they are heating up somewhat, we know current is going through them.
I cannot get schematics of the boards so cannot troubleshoot down to component level on them.
I would remove the plug from the motor and check it with a meter to ensure the windings are OK.
Also check that it is not jammed up.
[COLOR=Blue]
Where can I find a new control board if it needs to be replaced?[/COLOR]
See the parts link.
