My Maytag MHW6000XW0 is throwing a E01-F06 error. It turns on, lights up, but when you hit the start button in any mode you hear a few clicks and the unit does nothing with the exception of a soft thunking noise coming from the motor. After a few minutes it throws the fault codes. I checked the codes which are a communication error between the motor control and the main control board. So far I have replaced the motor control board, the main control board and I tested the wire harness from both control boards and it test fine, continuity on all 3 pins. Anyone have any suggestions?
Related topics
maytag washer f8 e2 error code | 1 | 2682 | May 16, 2014 | |
Maytag won't do anything | 4 | 1073 | April 15, 2016 | |
washer repair | 2 | 591 | January 23, 2015 | |
Maytag MFW9700SQ1 code F11 | 1 | 2750 | January 1, 2014 | |
Maytag Bravos Help | 1 | 817 | December 5, 2014 |
