Error code F01 and E02 on screen. Ran diagnostic check and wont make it past the second step of test. Error code comes up as MCU (master control unit). What steps should I take to solve problem or do I need replace the MCU???
I would go ahead and replace the MCU. It is an expensive part but if you buy it from this site and it does not fix things you can return it.
Good luck.
