Maytag electric dryer wont stay running
I replaced today the air duct by the tumbler. It was broken. I put everything together and it worked fine. I came home an hour later and my wife said the dryer will not stay running. It only runs if you hold in the start button. I have unplugged for 10 minutes hoping for somekind of reset. No lUCK. Please Help… Thanks George
Hi George
This problem is usually associated with a failure of the motor wiring. I would take the machine apart again and make sure you have good wiring connections to the motor.
If that does not fix it, you might want to change the timer out, as it is not expensive, but I fear that a motor replacement may be the solution.
Good luck
I have been using a "C" clamp to hold in start button and it has been working…How could it be the motor if it runs fine while starter button held in ?? Thanks for replying
My understanding is that the start switch can be checked by checking for continuity. I am having the same problem and found my start switch works fine.
