Maytag freezer water line issue
I have a Maytag msd2756aew side-by-side fridge that is suddenly leaking water from the water line area on the freezer side. I determined where the water is leaking from. Its a small dripping that is occurring in the bottom left corner of the freezer door.
I looked up some parts here and think it must be one of the following parts:
http://www.appliancepartspros.com/part_details.aspx?part_id=4071223
or
[Part Details - WHIRLPOOL CNTRL-ELEC, part number: AP4068351](http://www.appliancepartspros.com/part_details.aspx?part_id=3890557"]Part Details - WHIRLPOOL Connector, Water Tube, part number: AP3890557[/URL]
Is there any easy way of determining which one I truly need? Like I said, its a very small leak. Maybe one drip every 30 secs, but enough to be an issue and having to totally shutting off the water valve in the wall.
Also, while not as crucial, the ice dispensing flap in the freezer door no longer works either. The unit makes ice perfectly fine and dispenses it OK too. It just won’t open the door to let the ice fully through. I’m thinking I may need a new control board to fix this function. Specifically this part:
[URL="http://www.appliancepartspros.com/part_details.aspx?part_id=4068351)
Does this sound about right for this problem?
How difficult is it to replace both of these parts?
