maytag mav8557aww wont spin
The washer fills, drains, agitator moves, motor runs, belt looks fine. There is high pitched noise during spin cycle. The drum moves a little by hand but not much. Do you think it is the thrust bearing that is not allowing the drum to spin?
I think that is a good place to start. Fortunately the parts are not expensive and the repair is not difficult.
Here is the part you need. I think good instructions are included.
AP4009132
That’s the part I was thinking. How does that part work? I am placing the order now for one. How do you tell if the brake is stuck? How do you inspect the clutch?
I think there are good instructions with the part, but this site here says it all. (Make sure you go to the top of the page)
http://**************************.com/view_topic.php?id=22655&forum_id=2&jump_to=140630#p140630
That link did not work. The part just arrived tonight. I will be installing tomarrow after work. What is the purpose of a thrust bearing?
Sorry about the link, sometimes this site will not accept them.
The short answer is that it allows the brake to release. Here is a link to the service manual which will have a better discussion and diagrams.
http://repair2000.com/Library/maytagatlantiswasher.pdf
Well I got the parts out to install and then I found out that I was missing the spacer that backs up to the bearing. That sucked. I called up Appliancepartspros.com and they were helpful and understanding. I think they might be sending me a whole new kit. I will check out that link tonight since my work computer won’t allow it to open for some reason.
