washer won,t spin
took brake off tub spins easy,help
One of things causing such washer not to spin is break assembly is not disengaging.
You can find the complete instructions and learn how your washer works from the Service manual.
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=642384&&model_id=45823
Just checked the diagrams…Before replacing clutch and brake, you should check the thrust bearing. Matag makes a kit available for less than $50.
I am so sorry for the confusion. I was looking at a couple of completely different machines when I contributed to this thread. Everything I said about Thrust bearing kits applies to the MAV series, instead of the one in your OP. I apologize for not paying closer attention.
no ham done your intentions were good
