Maytag Maxima gets stuck in sensing
My Maytag Maxima Washer (Model #: MHW6000XW2) had the E01 F01 error.
I ordered (from AppliancePartsPros.com) and replaced the Electronic control board (W10427972). The Error is gone, but now, every time it reaches “Sensing” the machine gets stuck. It will not move past that step.
It does not matter how I get to that step, Big load, small load, rinse and spin or even in Quick Diagnostic Test it gets stuck at C06 and I need to abort without results.
Water fills (hot or cold), drain pump is working, I cleaned out the drain strainer.
