Maytag not agitating
I have an issue with my clothes washer. I first noticed it when the spin cycle wasn’t working and my clothes were soaked. After watching the entire cycle, I found that the agitator wasn’t moving. I changed the belt and I know that the lid switch is working because the motor actually stops when I open the lid. I have not had trouble with the spin cycle since. At one time when the agitator quit I was able to give it a twist and then it worked fine for a few days. Last night the spin cycle worked, but the agitator wouldn’t cycle now matter what I do, it seems whatever the issue is has finally died completely. It turns one direction with some resistance, and the opposite seems free. I have heard that their is a coupling that may have issues? Any direction or help would be greatly appreciated. Thanks
Remove the front panel, remove the belt and move the transmission pulley manually in both directions. Turning the pulley CW should oscillate the agitator and turning CCW will release the break for spinning action. Post the results.
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=689881&&model_id=47852
