Maytag washer wont spin/agitate
My Maytag washer has stopped spinning/agitating. It fills and drains properly. I pulled the front panel and verified that the belt is on and feels tight. I could manually move the belt and it moved freely. When I put the washer on the spin cycle the belt was moving but I could not see any movement inside the unit. I suspect the transmission but want to know if there are some steps to verify that this is probably the issue.
Gerard
