maytag outer lower tub seal leaking
Hi, My washer is leaking from the outer lower tub bearing seal. How do you remove the rubber seal,(bellows)? I can see a spanner nut inside the bellows but do not see any threads? It feels like there is a spring inside the bellows. Does the inner sleve come out first? HELP
