Maytag oven
When opening the door the clock flashes 3 times then powers off for 30 seconds. This cycle continues while door is open.
Hi.
It’s sounds like the problem is in the oven light circuit. If the light itself is
OK, check the door switch (#6 on diagram #2) and wiring between them and control board.
If everything checks OK - replace the control board/clock.
The clock [part]AP4097369[/part]
Here are the breakdown diagrams and Replacement parts for Maytag MMW5530DAB WALLOVEN- S/C MWAVE ELE | AppliancePartsPros.com
You can always return any unused parts even if they been installed.
Thank you. Post the results.
Simon.
