Hi need a little help here I have the above mentioned washer and it will spin but the water but the agitator still agitates while it is spinning then when you open the lid and shut it again it wont spin the motor is running pulley and pump look good also a grinding or vibrating noise is coming from the washer can’t pinpoint the source of the noise
— Begin quote from splash4321;296287
Splash,
Sounds, like you need a new thrust bearing kit (Iwould replace the belt as well).
[part]AP4009132[/part]
[part]AP4024823[/part]
That bearing assembly determines what the brake does and if it’s warn out it will not engage the gears to agitate properly, or will not set the brake properly in the spin cycle, and cause everything you’ve described.
Good Luck
More info still think it is the thrust bearing?
— Begin quote from splash4321;296338
Splash,
If You mean a white looking, feeling powder on the base of the machine,
That’s normal, the unit uses Corn Starch as a lubricant between the base and snubber (suspension system) and doesn’t have a lot to do with the gearcase, agitate and spin process.
Yes, I still think you’ve got a thrust bearing problem, or that’s where you should start.
The alternatives are a whole lot more expensive.
I really apreciate your help
— Begin quote from splash4321;296372
You’re quite welcome,
Drop us a line, if or when you need assistance,
We’re here to help, as best we can.
