Hello, My stackable washer is not filling with water. Everything else works. I did look up parts and found a ‘fuse block’. But when I looked at the ‘fuse block’ inside the washer, there was no fuse.
Does the ‘fuse block’ hold the fuse, or what?
Well this is a mystery since I believe it requires a 1 amp fuse to run, and I cannot say where yours has gone.
Yes, thank you! Also, is it possible to by-pass the lid switch (which I found works in sinc with the fuse) in order to avoid the whole fuse problem?
Thanks again!
Why not just stick a 1 amp fuse in there? Also, check the assembly and see if the fuse circuit was not by-passed in some way that has now come undone. If it was, don’t redo it, that fuse is there for a reason.
Don’t by pass the lid switch, it is a fairly big safety issue.
