I have a maytag stack. The washer will not fill with water. I found the fuse was blown. I replaced it and it worked for one load then the fuse popped again. I replace the fuse again and now when iI pulled the switch to turn it on the fuse blew immediately. Now im back to the beginning. When i turn the timer the washer will spin but no water. Please help. Thank you
Can you tell us which fuse is blowing, is it one inside the machine or your house fuse?
The fuse inside the machine is the one that is blowing
The fuse inside the machine is the one that is blowing[QUOTE][/QUOTE]
You are going to have to trace out the wiring to see if it is pulling too much current. If that is not it the problem may be in your motor or motor circuits, or something jammed in the tub.
Here is a service manual for a different Maytag stacked unit which may give you some help (or may not, but I hope it does)
http://www.servicematters.com/maytag_library/docs/16000416.pdf
