Maytag - The dreaded Ice AND Water not dispensing...
Pressing a glass against the switch, nothing happens. No noise, nothing.
So - I have searched online, and found that this apparently can be fixed by replacing a bad door switch or a bad dispenser board for Maytag fridges.
However, when I search using my specific model number (msd2573ves01), I am just shown the door switches. So my questions are:
  1. Is there not a replacable dispenser board for this model?
  2. If I press the freezer door switch, the light goes on and off. Does that mean the door switch is OK? Or should I still check it for continuity?
  3. The filter needs replacing - that cannot cause this, can it?
Thanks!
