Maytag Washer spins instead of agitating
My maytag washer fills properly, then starts to spin instead of agitating, causing water to splash out the top. The motor reverses like it should for the spin cycle and the belts look fine. The brake doesn’t seem to be working either.
It does spin and pump out in spin cycle. Is the trans. hard to rebuild?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
