Maytag washer sprays water
Hi, my Maytag washer will occasionally splash/leak water out of the injector sleeve when filling. What would cause this and what part, if any, do I need to replace…
— Begin quote from Rocky56;264168
Rocky,
You most likely have deposits built up on the injector valve and nozzle,
under certain conditions(water pressure, usually)can implicate an intermittent leak.
I reccomend you replace the:
Injector valve
Injector nozzle
Hose clamp
clean the calcium deposit from the plastic housing,
and clean the hose and valve screens of debris.
[part]AP2920314[/part]
[part]AP4025333[/part]
[part]AP4025626[/part]
Good Luck,
Thanks Joe, I will give this a try…
— Begin quote from Rocky56;264184
You’re welcome,
Glad to have helped,
