Maytag Washer Water Intake Leak
My Maytag washing machine leaks from the water discharge port into the tub after the washer is finished. I suspect the water intake valve. No water spills on the floor, only into the tub. If it is the intake valve, is that difficult to replace on this model?
Yeah, the valve is stuck partially open and you need to replace it or shut off your water at the faucet after each wash, which is no fun at all.
Here is the part
AP4027832
and it is not a difficult repair.
You should be able to access the valve assembly by inserting a screwdriver in the gap between the top and front near the edges to release clips that hold the top to the cabinet. It will flip up giving you access to the valve assembly.
