Maytag washer won't spin fast enough
Maytag washer won’t spin very fast during the spin cycle. I changed the thrust bearing but when I manually try to turn the wheel counter clockwise the tub won’t move. Seems it might be something in the brake or the brake isn’t engaging or something. Thanks.
When you replaced that pulley kit, did you get one of the washers on the very bottom before the C clip was put on?
Yes, got the thick washer on there.
Can’t get both the thick and one thin one on there.
Thank you. Was the pulley kit replaced because of this problem initially? When you turn the pulley, does it keep turning even though the tub does not or does it stop?
Yes, pulley keeps turning even though tub does not. I can push the little cam that is underneath the c-clip and washer with a screwdriver to where it seems to "lock" and the tub will turn very slowly. Otherwise it won’t turn at all.
Did you put lubricant between the two plastic cams when installing the kit? When you turn the pulley, can you see the white cam travel down in the center of the pulley?
Yes, lubed both pieces. Cam moves with the pulley, it does not remain stationary. I have to manually move it.
For whatever reason, the pulley is not moving upwards. I can spin the pulley freely but it doesn’t engage the transmission.
Did you get the white cam in correctly? It really has no choice but to drive the pulley up when the pulley is turned.
Yes, I installed it correctly. It’s almost as if there is something keeping the brake from going up or compressing the spring that is inside the brake. May take it apart today and see what is going on inside. The shaft of the transmission will turn without turning the brake.
While not running, you can move the bottom of the agitator in either direction?
yes, I can but clockwise is difficult.
It turns easily counterclockwise?
Yes, if I grab the upright portion. If I grab the very bottom next to the tub, it turns the whole, tub and all, in either direction.
If you have the lower pulley on correctly, your transmission is likely faulty.
OK. Thanks. Yes, I am certain that I installed the pulley correctly. Followed the directions that were included in the part.
Probably time to go washer shopping then…
