I heard some rumbling when my dryer started up. It only lasts a minute or so. When I removed the back panel to investigate, I found the blower wheel to have some play. When I manually spin the drum, the blower wheel seems to "skip" at times. It has to catch up with the turning of the drum. Why is this happenning? Should I replace the blower wheel? Has something (age) caused the wheel to have more play than usual?
Any info would be very helpful. Thank you.
Mike
