Replacing a terminal block on this wall oven. Old one had shorted due to loose wires.There was a small circuit board called an electronic filter on the old block. The new block does not have one nor does it show on the parts diagram or is it listed on the parts list. There are no instructions with the new block. Is this part not nesscessary now? It is burnt also.
— Begin quote from Blake1111;192618
The electronic filter is not used anymore for this model. All wires should be connected the same way as to the old terminal block.
— Begin quote from Gene;192651
Thank You.
