I checked my circuit breakers and they are fine. The 3-prong outlet works and is fine. My dryer runs and runs and never gets hot and never turns off. It has to be shut off manually. I have replaced the following
and cleaned out all lint from everywhere. Am I missing something? Please help.
AP3094244 (279816) - Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat)
AP3132867 (3392519) - Thermal fuse (disposable, one time fuse)
AP3131941 (3977767) - Thermostat, fixed
AP3094254 (279838) - Dryer heating element
AP3131939 (3387134) - Dryer cycling thermostat, L155-25
[SIZE=3]Hi: [/SIZE]
[SIZE=3]My dryer works only on light loads. You start it and begins a shaking motion until it stops. If I keep the start button on, it seems to work fine but if I let it go, sometimes it works fine for a while, and other times it starts shaking and shuts off. Any advise?[/SIZE]
[SIZE=3]Thanks, [/SIZE]
[SIZE=3]Luis[/SIZE]
I have a Whirlpool range that I want to covert from Natural gas to LP gas. It is model SF387PEYQ6. Can anyone provide me with instructions and diagrams to aid me?
I have a General Electric Dryer DDE7500 VAL WH with a serial number of 42288G.
The belt broke. In reviewing your site I cannot exactly match my model number to any of the choices you provide. Is my machine that old? I called in and spoke with Hannah F. She was very helpful!
Can you guide me please to the correct belt? I don’t want to depend on measuring the old belt, which snapped. I am not sure if there are fragments somewhere in the dryer.
Hannah said I might need to replace the drum bearing as well.
As I am looking at your diagrams and the back of my dryer they don’t match up.
Question: Is it possible that I don’t have a bearing on the back of my drum, but that the belt just wraps around the drum, the motor pulley and the tension pulley. I do see a wear mark on the drum, which lines up with the motor and tension pulleys. I am not sure if this mark is from rollers or the belt.
