Based on the number of posts on Dacor F1 problems and the limited number of replies and follow-ups either no one knows what to do or people replace the ECR at $400 and go happily on their way. In the interest of the psychological well-being of other Dacor owners, I implore those who have resolved this issue, to please speak up.
Meanwhile, I will tell you my long tale.
I bought a floor model dual-fuel RSD30 for a not-yet-built kitchen. Once the kitchen was ready, the range went in. It all worked out just fine except for an F2 error. I replaced the oven sensor for about $50 because I did not want to get into the guts and find something more expensive. Luckily, it seemed to fix the error and all was okay for a while.
After a few months of use, it started to give an F1 error. This started right after shutting off the oven from any mode of cooking. It usually took a few times (maybe 3-5) of canceling the beeping before it stopped. Sometimes I opened the oven door and this seemed to stop it from recurring. I thought it could be too hot – it was also a way to get the fan to stop running sooner, as I found that annoying. It would stay on for hours.
Then it got worse. The F1 error came on in the middle of the night (usually 3 or 4 am) about 8 hours after the oven was used. Then it happened at 4 am when I hadn’t used the oven in days. I thought it was related to the damp weather (don’t ask me why I thought that–grasping at straws). Then, it wouldn’t work at all. I tried all the oven modes, but it started to heat for about 10 seconds and just shut off, giving me only the time.
I did a self-clean cycle to give the oven a work out (don’t ask me why I thought that would help, either). It did the self-clean just fine, but then at the end it beeped and beeped F1 and wouldn’t stop; the door was locked. I shut it off at the breaker. The next day, after it had cooled, I turned it back on and the door was unlocked, but it started beeping F1 again. I couldn’t get it to stop.
I was, however, able to use the oven again. It worked. But the beeping is now a permanent state of affairs after the oven is done cooking. I have to turn it off at the breaker.
Diagnostics:
Disconnected touch pad, turned oven power back on, got F1 errror.
Checked the voltage for the J2 1-3 pins: reads 24volts.
So, does this mean the ERC is shot for sure?
I saw this post and wondered if there was anything to it–has to do with the door latch. Sounded like my original problem:
http://www.technicianbrian.com/2008/11/dacor-range-f1-error-code.html
Thanks for your help. I PROMISE to post a follow-up for the benefit of humanity.
